1 members (JW51),
96
0
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#40365 05/21/2002 4:06 AM | Joined: Sep 2001 Posts: 13 Member | | Member Joined: Sep 2001 Posts: 13 | hey there. I am redoing a '70 250 out of a nova with a 292 cam and some goodies for my 50 fleetline. but I need to know where to find engine bearings. also a 3x1 setup for carbs. thanks, justin
justin kohut 1950 fleetline/kustom 1950 Buick super (straight eight)
#40366 05/21/2002 4:58 AM | Joined: Jan 2002 Posts: 18 Member | | Member Joined: Jan 2002 Posts: 18 | Have you checked your local Napa? If the motor is out of a '70 they should be able to get them for you.
You only get one shot at life. Better have a good aim! Later Dudes Joe
#40367 05/21/2002 1:22 PM | Joined: Dec 2001 Posts: 146 Member | | Member Joined: Dec 2001 Posts: 146 | justin kohut
Remember that the fuel pump lobe on the 292 cam is in the wrong position to be used in a 194/230/250 block, so by doing this swap You'll have to run an electric fuel pump. As for the carbs, try Clifford, in the inliners site there is their adress, I don't have it.
Alexandre Garcia
