5 members (diseasel, Johnny Rib, Nick in Manitou, Hotrod Lincoln, Hanks custodian), 102 guests, and 2 robots.
Topics128,035
Posts1,055,559
#40365 05/21/2002 4:06 AM
hey there. I am redoing a '70 250 out of a nova with a 292 cam and some goodies for my 50 fleetline. but I need to know where to find engine bearings. also a 3x1 setup for carbs. thanks, justin
justin kohut
1950 fleetline/kustom
1950 Buick super (straight eight)
#40366 05/21/2002 4:58 AM
Have you checked your local Napa?
If the motor is out of a '70 they should be able to get them for you.
You only get one shot at life.
Better have a good aim!
Later Dudes
Joe
#40367 05/21/2002 1:22 PM
justin kohut
Remember that the fuel pump lobe on the 292 cam is in the wrong position to be used in a 194/230/250 block, so by doing this swap You'll have to run an electric fuel pump. As for the carbs, try Clifford, in the inliners site there is their adress, I don't have it.
Alexandre Garcia
