| | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I know that it is often recommended to raise the truck and take the load of the wheels to lubricate king pins but would this also apply to lubing a shackle bolt? I have new shackles/bolts but one is very reluctant to take grease. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It shouldn't make any difference, however, if you want to get the load off of it, you will have to support it by the frame, rather than the axle to get the weight off the shackle. I would be more suspect of a stuck/dirty grease fitting before a loaded/unloaded issue.
Bill Burmeister | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I would support it from the frame. I will take out the fitting although it was a new one which came with the shackle bolt. I have been getting grease into the bolt but with an excessive amount of pressure. | | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | Insert a long pry bar, the longer the better, between the spring and the frame, near the shackle pin, and work the spring up and down with the pry bar while you try to inject grease into the fitting. Leave weight on the wheels and be careful; the pry bar can slip on the spring while you are pushing on it. It takes two people to do this. The plugged fitting is also a good possibility.
Harvester | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I've had brand new zerk fittings with casting flash that kept them from allowing grease through them.
If this is one of the stock funny threaded shackles, it may be that the grease hole happens to be sitting pretty tight on the shackle threads and there's not much clearance in there for the grease. It will probably wear in eventually but exercising the shackle may make it easier. I would just have somebody jump up and down in the bed when I was greasing it instead of bothering to jack it up.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | When I removed my springs and shackle assemblies I was amazed at how tightly packed the bolts were with dry grease.I had to soak and ream the old grease out.If your bolts haven't been lubed in a long time,this might be the case with yours,not allowing the new grease to flow.When you lube them,make sure you see the new grease squeeze out past the cork seals. The old grease will be most likely grayish and the new darker.Then you know you've really packed it with new lube.
Drew
| | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | It took me two days to lube my truck I put new fittings on but it was still tough to do...I have one of those high end lube guns and kept trying until I felt I had enough lube in. If you have compressor you can get grease guns for them I would try that approach... Peter | | | | | Joined: Aug 2002 Posts: 221 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Aug 2002 Posts: 221 | Hi olblu!
Harvester's suggestion will most likely work. That's the way it usually worked when I was doing that stuff over 50 years ago! An easy 'fix' if it does work! | | |
