0 members (), 78 guests, and 12 robots.
Topics128,021
Posts1,055,355
Members48,420
#402289 04/15/2008 2:12 AM
can i start a 6v truck using a 12v battery and if so how do i go about it want to find out if the motor is good before i go to truble of buying a battery and all that stuff
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
apart hillbilly #402293 04/15/2008 2:20 AM
Pull the plugs and see if you can turn the motor over, with the fan belt or if there is a bolt holding the damper put a socket on it. The 6v starter should handle 12v without a problem.
Larry
I don't own a vehicle that isn't old enough to drink.
apart hillbilly #402296 04/15/2008 2:25 AM
jdl Offline
Well, I've asked this question myself. Yes, you can start the truck with a 12v battery. You can take the battery, hook it up as normal, and if it's anything like my truck(which by the way, what year do you have?) disconnect the smaller wire on the starter. Then disconnect the positive on the coil and place a wire from the starter to the + on the coil. Don't forget to tape up the ends off the wires you disconnect and either label them or remember where they go. After this, to be safe(I'm not clear on this myself if you have to do this part) disconnect the wires on either the generator or the voltage regulator. The regulator, if you don't know, is a black box on the firewall about the size of a spam can. You can verify this by following the wires to the voltage regulator from the generator. That's what I was told when I asked the same question. You can also, if you want to, go through something I found a little harder and disconnect the temp/oil/gas/amp gauges and then the generator and leave the rest alone. But after one of those two hook up the battery and start it up(first method doesn't require a key but second does)
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
jdl #402298 04/15/2008 2:27 AM
jdl Offline
Forgot to mention that your coil won't like 12v for too long.
Jordan D. Long
Photobucket
jdl #403310 04/17/2008 4:41 AM
Many moons ago my buddies and I were camping out in the Texas hill country. When we were ready to drive home we discovered my 48 Plymouth's (flathead 4 banger) battery was dead. There was a 18 wheeler trucker near by and offered to jump it off with his truck's battery a 24 volt. Boy you should have see that flathead turn over. It was spinning like a top.
~Jim
BIG CHEVY 3600 #403316 04/17/2008 5:14 AM
BIG,
I have played with the '48 flathead, but it sure wasn't a 4 banger! Maybe they were different in the backwoods of Texas. smile
Stuart
atomarc #403381 04/17/2008 2:04 PM
Your right Stuart it was a 6 banger. But never the less our "back woods" are smarter than your "back woods". grin
I guess my mind was fixating on 4s. My wife just bought a 4 cyl Camry and a friend of mine is trying to put a hemi in a 40 Willis. Of course as you know Stuart, the 4 cyl in there was mighty small.
~Jim
