0 members (),
62
7
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 305 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 305 | can i start a 6v truck using a 12v battery and if so how do i go about it want to find out if the motor is good before i go to truble of buying a battery and all that stuff
ya I know a few rednecks.Thay all drive chevys to, Proud member of the Old Dominion Stovebolt Society AND A MARINE trucks range from 1942 1/2 ton to 1965 fire engine
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Pull the plugs and see if you can turn the motor over, with the fan belt or if there is a bolt holding the damper put a socket on it. The 6v starter should handle 12v without a problem.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Well, I've asked this question myself. Yes, you can start the truck with a 12v battery. You can take the battery, hook it up as normal, and if it's anything like my truck(which by the way, what year do you have?) disconnect the smaller wire on the starter. Then disconnect the positive on the coil and place a wire from the starter to the + on the coil. Don't forget to tape up the ends off the wires you disconnect and either label them or remember where they go. After this, to be safe(I'm not clear on this myself if you have to do this part) disconnect the wires on either the generator or the voltage regulator. The regulator, if you don't know, is a black box on the firewall about the size of a spam can. You can verify this by following the wires to the voltage regulator from the generator. That's what I was told when I asked the same question. You can also, if you want to, go through something I found a little harder and disconnect the temp/oil/gas/amp gauges and then the generator and leave the rest alone. But after one of those two hook up the battery and start it up(first method doesn't require a key but second does) | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Forgot to mention that your coil won't like 12v for too long. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Many moons ago my buddies and I were camping out in the Texas hill country. When we were ready to drive home we discovered my 48 Plymouth's (flathead 4 banger) battery was dead. There was a 18 wheeler trucker near by and offered to jump it off with his truck's battery a 24 volt. Boy you should have see that flathead turn over. It was spinning like a top.
~Jim
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | BIG, I have played with the '48 flathead, but it sure wasn't a 4 banger! Maybe they were different in the backwoods of Texas.  Stuart | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Your right Stuart it was a 6 banger. But never the less our "back woods" are smarter than your "back woods". I guess my mind was fixating on 4s. My wife just bought a 4 cyl Camry and a friend of mine is trying to put a hemi in a 40 Willis. Of course as you know Stuart, the 4 cyl in there was mighty small.
~Jim
