Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (baldeagle, carbking, 2-Ton), 28 guests, and 3 robots.
Topics128,005
Posts1,055,254
Members48,418
#402397 04/15/2008 8:33 AM
im going to paint my truck soon gloss black i have a jar of flakes from house of colors can i just add that to the paint as i spray it iv never used flaks but always wanted to any body here ever use metal flakes
32fire2 #402465 04/15/2008 3:14 PM
32,
I only ever had flakes added to a paint job once ...on my Old Harley tanks an fenders an the painter had a spray gun with a air powered mixer built in his paint cup to keep the flakes suspended in the paint mix, now that was a long time ago! for sure!
Nowadays there may be a NEATER thingy out there for mixin flakes in the paint.
Im sure the PAINT GODS will chime in and know more than I ever will.
Tim
1952 Chevy Shortbed
Photos in Photobucket
32fire2 #402480 04/15/2008 3:40 PM
32,
Tim
1952 Chevy Shortbed
SW_Radial #402872 04/16/2008 5:13 AM
If you've never painted with flakes before, you're in for a big surprise. With flakes, you don't just mix them in the paint. It's a long drawn out process with a lot of steps. Do a search into the process before you decide that this is what you want to do. I've been custom painting car and trucks for 30 years, and I hate tackling a metal flake paint job. It's a lot of work, a LOT of work and very little room for mistakes.
Frank
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now.
http://www.coxcustomcars.com/
countilaw #402888 04/16/2008 7:29 AM
looked like on the tv showes they just dumped it in the clear and shot away dont the flakes just blow threw the gun im just going to have to give it a try
32fire2 #402895 04/16/2008 8:21 AM
I painted a bike tank with a pretty wild orange pearl that came out great, it was easy. The pearl was in the base coat and it wasn't hard to keep mixed, although I didn't have to do a large area. Pearl is a bunch easier because the flakes are really small and stay suspended in the paint for a long time. The older types of flake don't do this so well.
I don't think you want to be putting flakes in the clear coat, it will interfere with final buffing as it rips the flakes out of the pores of the paint.
Paint & Body Shop moderator
4ontheFloor #402907 04/16/2008 11:42 AM
Depending on the size of the flakes, you'll have to use a ton of clear to get the flake buried.
It has to be color sanded and buffed to smooth it out,and if you get into the flake it will ruin the paint job.
Major paint companies have a lot of glamour finishes that produce a beautiful job with a whole lot less work.
Wally Body #403232 04/17/2008 1:57 AM
It really does depend on how coarse the flakes are like Wally sez.
I've seen metalflake go down so coarse it feels like sandpaper. Then it has to be sanded with like 400 wet/dry and clear over which has to be sanded... then it has to be compounded and polished.
If I were you, I'd definitely paint some test panels before committing to painting an entire vehicle.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Czechman #403421 04/17/2008 4:56 PM
I have not ever used flakes before but just sitting here thinking about it, if the flakes were dumped right into the paint mix wouldn't they clog up the tip on the gun when sprayed?
Again I don't know a lot about it but there must be some kind of special equipment that is needed to do a job like that isn't there?
Czechman #403423 04/17/2008 5:13 PM
I have sprayed several motorcycles and snowmobiles using
metalflake which is a brand name.....NOW, you do not mix flake
in the paint....It is a separate procedure...The flake is sprayed
on as a ground coat, the same as Your pearls are...It is added
to the paint cup of proper viscosity of lacquer clearcoat, then
color added after desired flake is obtained...Flake is very heavy
and if not continually agitated will cause You very negative results...I used a couple of large ballbearings in the paint cup,
continually shaking the spraygun...While the results were happily
accepted by the owners, metalflake is a pain in the knickers...
You might look into the new systems offered today..Plastic
micro-chips are used instead of metallic, and therefor much easier to spray, and endurance is much better...Bill B
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
Bill_B #411254 05/09/2008 10:01 AM
Apprentice
Apprentice
Here found this site maybe this will clear the air a little for you,check it out there's even a how to section!!
http://www.tcpglobal.com/kustomshop/ksflake.aspx?gclid=CL_A4O_3xZECFRGCGgod3yVb4Q
smile
