| | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | Does anyone know if there is a patch panel sold for the front fender, 47/53 BOTTOM LOWER FRONT AREA? I did find some for the rear fenders. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | no luck here, looked in my many catalogs. Sorry
| | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | All the lower front part of the fenders are the same from '47-54 as long as you don't go up to high. The '54 had a difference how the grill mounted and the parking light area. Find a good used fender and hackout the piece you need.
Bruce | | | | | Joined: Dec 2006 Posts: 113 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 113 | I have searched and searched and decided I will just replace the fender. I'm kind of surprised that they aren't available since most I have found are rusted out in the same place as mine. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Don't give up looking just yet. While the big vendors might not carry it you might run across someone that makes them himself. Do a search here on the Bolt. A year or two ago the subject was covered and there was a guy that had a shop that specialized in sheetmetal refab.
~Jim
| | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | Thanks very much for all the great info and Ideas. I will try to find another fender. If not I will attempt to carefully fab out several pcs and weld them in little by little. If I can get close enough perhaps I can make a reverse shape from a friend who has the same fender and use it as a gauge to fill in with bondo. I love this hobby it challenges me all the time. Like Redgreen says :If the women don't find you handsome they should at least find you handy. | | |
