| | | Forums66 Topics128,080 Posts1,055,945 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#40278 03/27/2002 6:36 PM | Joined: Mar 2002 Posts: 1 Junior Member | | Junior Member Joined: Mar 2002 Posts: 1 | Looking for any info where I could find a bell housing for 1956? clark housing, I have model number if that is needed, thanks for any help or a point in some direction, Coon Rapids Fire Dept Restoration Team
I got some numbers now from this housing 1956 GMC 302 Clark# 202w217 Serial# 20021b Casting# 2753 GMC E2199 from other side Any Info Helps Thanks | | |
#40279 03/27/2002 11:51 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Welcome to Stovebolt. Ok, are you talking about looking for a bellhousing to go with a Clark transmission for a GM truck? | | |
#40280 03/28/2002 2:18 AM | Joined: Apr 2000 Posts: 247 Member | | Member Joined: Apr 2000 Posts: 247 | Typically, Clarks shared the same bellhousing patterns as the standard 1/2 ton and up trucks. You should be able to bolt up to a bellhousing that had a SM420 behind it which was common in 1956. You will need to get the bellhousing that is correct for your motor (six or eight cylinder). Clarks usually were put behind chevy motors in the bigger trucks, and since GM standardized everything possible, yours should bolt right up. | | |
#40281 03/28/2002 2:26 AM | Joined: Aug 2000 Posts: 197 Member | | Member Joined: Aug 2000 Posts: 197 | I don't know for sure about 1956, but the early clarks (pre 1953) had a different bolt pattern compared to the sm420 and the bellhousing was more bulbous to accomadate a larger clutch. What size flywheel do you have? Try Boyce Equipment (you'll have to do a search for the phone number or website)who has rebuilt clarks and may have a bellhousing for you. jason
Jason
#40282 03/28/2002 2:46 AM | Joined: Jan 2001 Posts: 45 Member | | Member Joined: Jan 2001 Posts: 45 | I am almost certain I have the bell housing you are looking for. It is on a 302 and it had a clark behind it It has ears bolted on the side of bell housing for rear mount I will look for the casting # on the housing do you need the clark transmission also ?? flywheel ?? clutch ??? I have the whole works Mike [email protected] | | |
#40283 03/28/2002 3:04 AM | Joined: Jan 2001 Posts: 45 Member | | Member Joined: Jan 2001 Posts: 45 | the casting # on mine is GMC 2135506 has a 11 and 1/2 clutch maybe 11 3/4 measures in between Mike Also has a extra heavy duty 6 volt starter with soleonid will part with all. Mike | | |
#40284 03/29/2002 2:24 PM | Joined: Jan 2001 Posts: 45 Member | | Member Joined: Jan 2001 Posts: 45 | Could you send picture of your housing I think I have what you need ? Mike | | |
#40285 03/30/2002 3:10 AM | Joined: Jan 2001 Posts: 45 Member | | Member Joined: Jan 2001 Posts: 45 | Jason I will know Thursday I have 2 engines with bell housings in storage in Nebraska on 302's I will check them Wednesday The one in my garage on a 302 is not like yours. Mike | | |
