0 members (), 140 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#40278 03/27/2002 6:36 PM
Junior Member
Junior Member
Looking for any info where I could find a bell housing for 1956? clark housing, I have model number if that is needed, thanks for any help or a point in some direction,
Coon Rapids Fire Dept Restoration Team
I got some numbers now from this housing
1956 GMC 302
Clark# 202w217
Serial# 20021b
Casting# 2753
GMC E2199 from other side
Any Info Helps
#40279 03/27/2002 11:51 PM
Welcome to Stovebolt. Ok, are you talking about looking for a bellhousing to go with a Clark transmission for a GM truck?
#40280 03/28/2002 2:18 AM
V
V Offline
Typically, Clarks shared the same bellhousing patterns as the standard 1/2 ton and up trucks. You should be able to bolt up to a bellhousing that had a SM420 behind it which was common in 1956. You will need to get the bellhousing that is correct for your motor (six or eight cylinder). Clarks usually were put behind chevy motors in the bigger trucks, and since GM standardized everything possible, yours should bolt right up.
#40281 03/28/2002 2:26 AM
I don't know for sure about 1956, but the early clarks (pre 1953) had a different bolt pattern compared to the sm420 and the bellhousing was more bulbous to accomadate a larger clutch. What size flywheel do you have? Try Boyce Equipment (you'll have to do a search for the phone number or website)who has rebuilt clarks and may have a bellhousing for you.
jason
Jason
#40282 03/28/2002 2:46 AM
I am almost certain I have the bell housing
you are looking for.
It is on a 302 and it had a clark behind it
It has ears bolted on the side of bell housing for rear mount
I will look for the casting # on the housing
do you need the clark transmission also ??
flywheel ?? clutch ???
I have the whole works
Mike
[email protected]
#40283 03/28/2002 3:04 AM
the casting # on mine is
GMC 2135506
has a 11 and 1/2 clutch
maybe 11 3/4 measures in between
Mike
Also has a extra heavy duty 6 volt starter with soleonid
will part with all.
Mike
#40284 03/29/2002 2:24 PM
Could you send picture of your housing
I think I have what you need ?
Mike
#40285 03/30/2002 3:10 AM
Jason
I will know Thursday
I have 2 engines with bell housings in storage
in Nebraska on 302's
I will check them Wednesday
The one in my garage on a 302 is not like yours.
Mike
