2 members (Otto Skorzeny, DennisM), 91 guests, and 5 robots.
Topics128,026
Posts1,055,403
Members48,422
#402648 04/15/2008 10:23 PM
We're restoring a 1948 gmc 1 1/2 ton with a 248 engine. There is no exhaust on it. We need to hook up an exhaust pipe but i'm not sure if the flange/coupler/heat riser valve(what's it called?) is the same on all engines, or if there's one specific to the 248 manifold. (it's the original manifold on a '51 engine)
And does anyone know if this part's common enough for Napa or someone to have?
Any good exhaust shop should have all different sizes available and likely NAPA too. I'd bet that all 216, 228, 235 and 248 engines used the same size.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
I think my 216 is either 1 7/8 or 2". I took it to the local exhaust guy that does older stuff and he did a great job. I asked him how long it would take to get the parts and he said that he would have it done in a couple of hours. He had everything on hand. One thing though, he used a doughnut gasket and the truck previously had been put together with a flat gasket. I think that his way was right.
1951 1 Ton Completed
