1 members (Rusty Rod),
80
Mod | | | Forums66 Topics128,127 Posts1,056,680 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#40227 11/14/2001 11:14 PM | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | '59 Fleetside LB If I put the tank between the rails, where would the filler tube and cap go? Has anyone done this conversion yet? Thanks for all the info in response to my earlier post.
"Happiness equals reality minus expectations" - Tom Magliozzi
#40228 11/15/2001 12:58 AM | Joined: Jan 2001 Posts: 47 Member | | Member Joined: Jan 2001 Posts: 47 | Jim A guy at Crusin the Coast here in Mississippi had a tank made with rear exit and used a fold down license plate bracket from 60's or 70's car. It looked sharp. I wasn't to thrilled with the 302 HO mistake motor in the truck though! | | |
#40229 11/15/2001 2:17 AM | Joined: Aug 2001 Posts: 21 Member | | Member Joined: Aug 2001 Posts: 21 | Behind the plate under the tailgate, or on either side of the truck in either fender or panel. It can go whereever you want it. I've see it all the time and everbody has it somewhere different or just a few inches different than the last person.
Nate
If you're clean, then you're not a 'Man' If your truck is clean, then your truck is a 'Queen'.
50 3/4T Chevy until it is traded or sold 48-55 1/2T Chevy parts until they're all gone
#40230 11/15/2001 3:07 PM | Joined: Apr 2000 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2000 Posts: 81 | inside the wheel well is another, at back behind license plate is cool. my 69 pontiac has hers there.
If at first you don't succeed, get a bigger hammer.
1941 Pontiac business coupe 1947 Chev Coupe 1969 GTO ragtop
#40231 11/15/2001 3:19 PM | | Anonymous Unregistered | | Anonymous Unregistered | Only trouble i have seen with behind the plate with a 58 is you have to hang the tank a little low,it dont fill real quick and when full does the ole spray out the cap trick(remember at the drag races,even with a great cap they used to dump fuel but it was only 45 cents LOL). In the bed is cool with a brass boat screw on cap.But most put it in the rear fender,its high so you can fill it easy. | | |
#40232 11/15/2001 6:06 PM | Joined: Feb 2001 Posts: 198 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 198 | Moving the tank to the back is a great idea, but the position of the filler cap is the killer. If it's a show/cruiser truck (not actually hauling stuff) then Phat's idea of the brass/stainless boat type filler in the bed looks great, but don't run low when you have something in the back. For those of us with fleetsides who want to 'use' our trucks hiding the filler seems to be a real problem. Phat, what about using one of the stake holes in the back corner. Running a line down and over to the tank and then putting a screw on filler cap? Me thinks that would solve the hose in the box problem and still make the filler accessible. Also, what about a Suzuki Samori or similar little 4x4 tank. Seems they sit between the frame rails on those things. Maybe a bit too narrow. My 2 cents.
Attitude - The difference between an adventure and an ordeal! Deja Moo - The feeling you've heard this bull**** before! '63 Chev Fleetside Longbox 'Rusto-rod' 'Big Red' '69 or'70 or ? Mantaray DuneBuggy
#40233 11/15/2001 7:58 PM | Joined: Apr 2000 Posts: 247 Member | | Member Joined: Apr 2000 Posts: 247 | I was rust hunting the other day in a junkyard close by. I noticed that filler caps from a newer Pontiac and Chevy Minivan had a self rimming setup, so all you would have to do to put one in is to cut a hole in the fender and install it. It also had a cable hookup, so you could set it up like most new cars and not have to have a locking gas cap. I also have pictures that I got from the 67-72 site that has it hidden behind a side marker light. If you all want to see it, have someone that can post pictures email me, and I'll forward it to them to post. | | |
#40234 11/15/2001 8:07 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | On my 37 pu , I made a small aluminum door to hide the cap access hole near the rear of the bed.The boat filler is a nice touch however.If you haul manure, remember to get fuel before shoveling in the crap.The fuel tank is located just in front of the rear crossmember. I welded in a rectangular tubing to provide a place to secure the straps at the front of the tank.Two more tubes are welded in at the top to give the tank a secure hold when the straps are tightened.The tank is about 2 feet from the rear of the bed and pushed up within 2 inches of the wood bed floor. It clears the axle by 2 inches in the front.Standing behind the truck ,you dont really notice the tank.Many sedans and SUV's have fuel tanks more exposed than mine made of 16 guage steel. [img] http://pstr-m02.ygpweb.aol.com/data/007/4F/A7/FD/6E/1ssguopgLZhAg496XeUJi2VuDbvcyTM00180.jpg[/img] [ 11-15-2001: Message edited by: Tony ] | | |
#40235 11/16/2001 2:59 AM | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Hey Judd, that must have been the blue longbed stepside with the coke trailer behing it. Was a nice looking truck I even took a picture of it, THEN I noticed the mistake motor under the hood. Oh well.
Tommy 59 apache 1/2t 261 short stepside | | |
