0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 7 New Guy | | New Guy Joined: Mar 2008 Posts: 7 | Is it possible to convert the front parking lamps on a 6V system to turn signals?
I have seen the conversion kits but they all state they are 12Volt.
Is this because there are no 6V two filament bulbs available that can function as signals?
OR
If there are 6V two filament bulbs available can I purchase the 12V kit, replace the wiring to a heavier gauge and hook it up?
The truck presently has rear signal lights only.
I will continue to search in the archives but if anyone has experience with this let me know.
Thank you
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There is no reason the conversion kit will not work with 6 volts. You can get the equivalent bulbs in 6 volt. I get universal sockets & replace them myself. The wire will be large enough for a short distance.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2008 Posts: 7 New Guy | | New Guy Joined: Mar 2008 Posts: 7 | Thank you for the reply.
I am looking to purchase a truck that is located a fair distance away. The truck will eventually be switched to 12V but I just need a quick fix to get the front signals operational for the drive home. Better safe than sorry.
My other option is to switch everything to 12V before heading out on the road and I will research that also. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Ah,just stick your arm out the window and point.Half the drivers in this country don't use signals when they have them.
Drew
| | | | | Joined: Mar 2008 Posts: 7 New Guy | | New Guy Joined: Mar 2008 Posts: 7 | You are right on that one Drew. My job involves driving so I'm on the highways everyday. Besides people talking on their cellphones, not using their signals is the second most common thing I see.
| | | | | Joined: Feb 2008 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 70 | it should work good..........unless you plan on making a turn that lasts 6 hours............... | | | | | Joined: Mar 2008 Posts: 7 New Guy | | New Guy Joined: Mar 2008 Posts: 7 | I've been known to go in circles sometimes! | | |
