0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#401623 04/13/2008 4:05 PM
Is it possible to convert the front parking lamps on a 6V system to turn signals?
I have seen the conversion kits but they all state they are 12Volt.
Is this because there are no 6V two filament bulbs available that can function as signals?
OR
If there are 6V two filament bulbs available can I purchase the 12V kit, replace the wiring to a heavier gauge and hook it up?
The truck presently has rear signal lights only.
I will continue to search in the archives but if anyone has experience with this let me know.
Thank you
Riding in the Passing Lane
There is no reason the conversion kit will not work with 6 volts. You can get the equivalent bulbs in 6 volt. I get universal sockets & replace them myself. The wire will be large enough for a short distance.
1972 Chevy c10 Cheyenne Super
Thank you for the reply.
I am looking to purchase a truck that is located a fair distance away. The truck will eventually be switched to 12V but I just need a quick fix to get the front signals operational for the drive home. Better safe than sorry.
My other option is to switch everything to 12V before heading out on the road and I will research that also.
Ah,just stick your arm out the window and point.Half the drivers in this country don't use signals when they have them.
Drew
You are right on that one Drew. My job involves driving so I'm on the highways everyday. Besides people talking on their cellphones, not using their signals is the second most common thing I see.
it should work good..........unless you plan on making a turn that lasts 6 hours...............
I've been known to go in circles sometimes!
