| | | Forums66 Topics128,009 Posts1,055,295 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 11 New Guy | | New Guy Joined: Jan 2008 Posts: 11 | For the really serious, a differential cylinder pressure testing tool can be invaluable. This device, properly used, allows you to very accuratly diagnose valve or ring problems. I'm still surprised by the number of pro mechanics who do not use them or think that they're not worth the money. Peruse one of the many sites dealing with the care and use of one to find out the story. I wouldn't be without mine as a basic requirement for engine condition determination. Plus it looks really cool in use. Only thing is, when you read where it is possible to get hurt using one, let me assure you that THEY ARE NOT KIDDING. Regards, Ken Beckman | | | | | Joined: Mar 2008 Posts: 38 Apprentice | | Apprentice Joined: Mar 2008 Posts: 38 | Handier than toothpicks at a sushi bar, a compression tester (most have included fuel pump reading as well), vacuum gauge, VOA meter, are invaluable tools for any mechanic. Add a remote starter and you're a one-man diagnostic center. Without them it is (expensive) trial and error. | | | | | Joined: Jan 2008 Posts: 11 New Guy | | New Guy Joined: Jan 2008 Posts: 11 | Not that kind of compression tester, Laurence. The kind you use on aircraft engines. Commonly called a leak down tester. Regards, Ken | | | | | Joined: Mar 2008 Posts: 38 Apprentice | | Apprentice Joined: Mar 2008 Posts: 38 | As in cored sparkplug attached to compressed air? | | | | | Joined: Jan 2008 Posts: 11 New Guy | | New Guy Joined: Jan 2008 Posts: 11 | | | | | | Joined: Jan 2008 Posts: 11 New Guy | | New Guy Joined: Jan 2008 Posts: 11 | | | | | | Joined: Mar 2008 Posts: 38 Apprentice | | Apprentice Joined: Mar 2008 Posts: 38 | Great article. I've always used the regulator at the compressor (or pinched the hose) to regulate the volume pressue on my home-grown tester. Having it closer to the working end is the better idea. However, I've only used the rig when shorting out, stethescope, or tailpipe flutter is not definitive. You are correct - it is an excellent method of determining internal cylinder condition short of a tear-down. | | |
