| | | Forums66 Topics128,266 Posts1,058,367 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | Im wondering what the difference between a 54 235 out of a car and a 54 235 out of a truck is. When I bought my 52 i was told by the person that i purchased it off of (a reliable source) that the previous owner who was working on restoring the truck before having to sell it, installed a "rebuilt" 235 that was originally from a 1954 chevy car (unsure which). My question is what would the difference be between a engine out of a car and out of a truck. Also does a powerglide tansmission automatically add 10 extra horsepower or what? Im confused on this powerglide stuff. If a powerglide is a trans then why would it be apart of the engine id number on the ledge of the distributor? here are a few sites i ran across to id my engine (id: XXXXXXXT54Z) http://chevy.tocmp.com/models/engine.htm#54enghttp://www.secondchancegarage.com/public/370.cfm
| | | | | Joined: May 2007 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 95 | Best i know? The head will be the big difference. Truck motors are about torq, Car motors are about HP. PowerGlide is a two speed automatic. Fast and Faster usually gets the job done. Drag racers like them alot.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | On the difference from a 'Glide 235 to a stick shift car 235 or a truck 235 is in the cam. A 'Glide engine has a hydralic cam with a bit more agressive lift. The reason for the need for the 'Glide engine needing more power is that the 'Glide takes more poer to operate.
Bill Burmeister | | | | | Joined: Mar 2006 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 77 | My ’61 had a 235 out of a car in it, and it was a very powerful engine. It would take you uphill at 70 miles an hour – and still be able to push you to the back of the seat! And it wasn’t wound out. Whenever my great-uncle would drive the truck he would say, “are you sure you don’t have a V8 hidden under there?!” I never could figure why it did that, as everything I have ever heard as said that those trucks just shouldn’t be able to do that - but it did. When I went through the truck, I found out that everything in it was original – except for the engine. So, anyway, that must be why my motor was so powerful – it was from a car. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The main difference between a 1954 car 235 and truck 235 is the car engine has hydraulic lifters with the Powerglide transmission. There were a few other "cosmetic" differences.
The standard truck 235 was about 112 gross hp and the various versions of the car 235 were about 115-150 hp (Corvette at 150, I think). The Corvette 235 had mechanical lifters, a 261 cam, and 3 side-draft carburetor.
All the 1954 235s developed about 200 ft-lb of torque | | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | is there anyway to tell exactly what it came out of. How can i tell if it has hydraulic lifters? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | One book says the 1954 car Blue-Flame 123 (hp) was standard and the Powerglide came with the Blue-Flame 136 (hp). | | |
