8 members (Gdads51, frogfarmer, Bill Hanlon, LAROKE, gswbbc, Forty9, 48jim1ton, Hotrod Lincoln),
107
0
Mod | | | Forums66 Topics128,043 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | Got my leafs apart ready for sandblasting. The rear shackles look real good after blasting and paint. Should I reuse the rear spring eye pins and retainer pins? There is some wear on the spring eye pins and the bushing look a little worn as well. The front spring shackles need replaced along with all front pins and bushings. Are there any vendors that sell these things for the 2-tons? If so...can you point me in the right direction?
Thanks...
| | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | Jim Carter lists them in the Catalog, Page 117 Cleon | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I bought every bit of hardware I need for my springs, as well as completely new springs, from http://www.eatonsprings.com/Including front shackles complete, bolts and bushings for rear ends of front springs, pins bushings and lock pins for rear springs and shackles, U-bolts and nuts for front and rear. Grigg | | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | I found a local truck shop and had them re-bush my spring and shackle and got new pins as well. Seemed the right course of action because they have all the stuff on hand to press them out/in and ream as needed. Also had them replace the center bolt and assemble the spring, the whole process is a lot easier to do with the right tools! 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I just had the rear springs etc rebuilt on my 53 flated and a local shop had all the parts at prices a fraction of some of the big catalog vendors. Most towns of any size have such spring rebuilders, hope our local guy lives to be a hundred. | | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | I've had luck with the local shops for parts as well but I've saved a ton having parts trucks with good non worn parts too. | | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | I was wondering if on your leaf springs there is GM-O embossed on the edges of the springs. I know this ain't no big thing but it happens to be there on the edges of my springs which are on a 52 chevy 2ton. I was just wondering if it is a common thing, but then rust could make it disappear. Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
