8 members (68ironhead, lumbersawyer, 48jim1ton, Woodcmiami, 3B, J Lucas, Ponchogl, 1 invisible), 97 guests, and 0 robots.
Topics128,049
Posts1,055,553
Members48,425
#399562 04/08/2008 3:48 PM
I'm going to get a new key for my locking door handle on my 1954 3100. It's situated on the passenger handle. I was wondering if I can switch the locking part over to the drivers side it will be easier to lock there... Any ideas Thanks Peter
Houston54
Unregistered
Houston54
Unregistered
You sure can but I would suggest you find another keyed handle and have the locksmith key them both the same for you. That way you have locks in both doors. This is what I did for my 54 and it works great. Cost of keys and re-keying was $65.00 which is much less than a new key set.
#399569 04/08/2008 4:02 PM
So Houston for now i think I'll stay with just one lock. I don't live in a bad area or leave my truck for long... So i can take the lock button from the passenger side and the regular button from the drivers side and interchange them with out a problem ... that will work great for me. Peter
Houston54
Unregistered
Houston54
Unregistered
Even easier is to just swap the handles. The key would be updside down but would work just fine.
#399581 04/08/2008 4:27 PM
OK i thought of that too thanks Peter
I moved the locking handle over to the drivers' side and it works fine on my 1954 GMC. That's the door used most often and it is a lot more handy.
Houston we have new key for my lock.... I took the handle off there was a number on the lock took that out.. Went to a lock smith he look the number up on the computer and bingo I have a new key $10... I went home and switched the Handles bingo done ... thanks for your help all...Peter
