| | | Forums66 Topics128,180 Posts1,057,153 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 24 | I want to put a 5-speed in my 57 3100 which presently has a 3-speed with a 235 six (for better mileage and lower RPM). I see that a T-5 out of a mid 80's S10 is recommended. How can I tell what tranny is a T-5? Were the same T-5's in both mid 80s 4 cyl and 6-cyl S-10s? Thanks!
Two 1957 Chevy Step Sides 1988 Fiero Formula 1987 Fiero GT 1984 Fiero Indy ... yes I like Fieros also.. ;-)
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Look for mid 80's. There is a chart on the Inliners web site showing all of the gear ratios for the various T-5's. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | be careful that you don't get one that has the electonic sending unit for the speedo, expensive to adapt. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There is a lot of info on this websight about this. There is a tag on a bolt that holds the rear housing to main housing. It has a number on it starting with 1352- The next 3 numbers are what identifies it. Like 1352-145. (the most common). 88 up had an electrical speedo drive & unless you are using custom gauges is hard to adapt like WE OLD says. The T-5 bolts to a bell housing. There were some trucks that had a trans. with the bell built in. That won,t work. Some early 80,s were 4 speeds, so watch the gear shift knob. If the knob is gone try shifting to 5 gear. Way over to the right & up. Go to www.mongosgarage.com for ID's. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
