1 members (baldeagle), 107 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#399056 04/07/2008 5:15 PM
Just bought a 1954 6100 2 ton, w/tandem axles and I need either to transport it or go get it and drive home the 600 miles. Nothing like jumpin into the fire. Been trying to get transport quotes but it seems that 2 pieces of additional information are needed; wheel base and empty weight. Could not find it in my truck shop manual. Need help. HELP!
fredico,
The 1954 6100s have a 137" wheel base. If no one posts the empty weight by this evening, I'll post it when I get home.
Tim
I've got a '49 Restoration Pack from Chevrolet. The weight listed for a 6103 is 4680. This is curb weight. They say this is the weight of an empty vehicle ready to drive. I think that the 49 wheel base is a little shorter than your but weight should be close. What kind of bed do you have? Also the info I have doesn't mention any weight for the tandem set up.
Don
It was used as a grain truck. So the bed sides are solid wood. A 3 piece gate on the back.
Thanks Tim this will surely help. It is an exciting time.
'54 6109S HD Stake 5530#
Platform, Stake Truck 540#
Racks, Stake Truck 238#
These are weights from Chevrolet.
They don't mention anything about the tandem set up, I'm sure because it was done someplace other than the factory.
I'd maybe add some weight to the racks if yours are solid, the picture that Chevrolet has shows spaces between the slats of the sides.
Hope this helps
fredico,
By tandem axles, do you mean 4 rear wheels?
The heaviest 6100 would be the stake bed with 8.25-20 tires on 4 x 6.5 rear wheels and 2-speed rear axle would be a little under 6,000 lbs (no fuel in tanks).
Tim
Thanks Don for your help. This information will complete what is needed. Now if I can find a company that is forthright and honest.
Tim,
The truck has 8 rear wheels. dual hoist cylinders. 2-speed rear axle, and I am not sure the size of the rear tires but the Steer tires are 9:00 20, as I am told.
fredico #399203 04/07/2008 11:25 PM
Hey fredico, If that's the '54 Tandem, I saw on ebay, Chances are it's a Tandem Conversion, by either, Trucktor, Truckstell, Fabco, or Grico. And if this is inded the case, you can throw all the standard Factory specifications, out the window.These Tandem conversions were done for Chevrolet by outside jobbers, until 1956, when the first Factory Assembly Line Chevrolet Tandems were produced. If it's like the '54 Chevrolet 5400 COE Trucktor Tandem, I had. It will actually consist of a separate set of frame rails, with the tag axle attached, that will slide over the factory frame rails, all the way under the cab. If this is the case you can figure in an extra 1500-2000lbs., of weight to the factory 6100 spec.'s. Hope this hasn't confused you. See my '54 Chevy 5400 COE chain drive Trucktor Tandem here, http://rides.webshots.com/photo/1115990817052570246iKfhhf . Put an ad for transport on the hauling schedule of, www.yesterdaystractors.com . I did this for transport of my recently aquired GMC COE. Got several replies,& offers within days.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
spanky #399207 04/07/2008 11:49 PM
Spanky,
It is the same truck you saw on ebay the last few weeks. Once I get the truck home and have a chance to look it over, the questions will be numerous. You are absolutely correct about what is the future...COE! So much to learn, so little time. Can't wait to start. thanks.
What part of Virginia, are you in. I go to Virginia Beach, Roanoke, & Danville, on occasion.
Spanky Hardy
1950 GMC 250 1-Ton
spanky #399470 04/08/2008 11:24 AM
Spanky,
Good morning. We live in western Loudoun county on the Clarke county line. So close that the first 1500 feet of our driveway is in Clarke county. One half mile north is West Virginia. Looking at a map of northern Virginia bordering West Virginia at the bottom point of the V is where we live. Looks like on a map maybe 4-5 hours from Burlington.
Been look'n through a 1954 "Chevrolet Truck Data Book, Specifications Catalog for Chevrolet salesmen" and the type truck example pages for vocational use show a 6403, 6103 and even a 5403 all with tandem rear axles. I wrote Chevrolet to find out ifin a vehicle archival information base is available to the general public. No reply just yet. If there is such a site, I will gladly w/great haste share w/all. Also shown was a "dually" 4 door "Crew cab" C.O.E. It is what dreams are made of.
did you call for a gm restoration pack. got one in a few days and it's free. you provide your vehicle serial/chaissis/vin number as applicable. the pack i received had build specs part numbers etc. plus a list of speciality clubs and gm licensed restoration parts suppliers.
kb3csw #407520 04/28/2008 6:08 PM
kb3csw, Sounds great but don't know anything about the gm restoration pack. What was the number to call?
