| | | Forums66 Topics128,261 Posts1,058,344 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 360 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 360 | have a 46 1/2t pu. just pulled the gas tank and found i only have a top 1/2. have looked at the usual parts sites and done a general google search and ebay w/ no luck. where do you guys and girls usually go for new tanks?
does anyone know the range of make model year that are replaceable in this truck? a model # for the tank? i am waiting on my manuals and don't have this info handy.
thanks
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | bowtie bit has one made from stainless steel for about 600 or so. I would put an add in the parts wanted section and see if you can come up with a good used tank for less money. | | | | | Joined: Aug 2005 Posts: 278 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 278 | 41-46 will be a perfect fit. 39 will fit and work but drain hole on tank bottom is in a differnt location. Not certain about 40. I would think chevy and GMC would be the same. You may find slight differences in capacity with bigger tonage. | | | | | Joined: Feb 2008 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 70 | theres a couple on ebay now forsale....100 bucks for a used one and about 200 for a new one......hard to find and expensive as usual........ | | | | | Joined: Mar 2008 Posts: 32 Apprentice | | Apprentice Joined: Mar 2008 Posts: 32 | I don't know if this helps but my dad hatted the gas tank coming from the center of his 46 Chevy panel truck (really small tank) so we removed it and placed a tank under the rear of the truck with a small goose neck coming up flush to the outside of the truck. We used a Polyethylene Gas Tank out of a 53 Chevy car including the fill nozzle. It even came with the straps! Jason Here's were we bought it http://www.nationalchevyassoc.com/shop-online/product/1117.html | | |
