| | | Forums66 Topics128,135 Posts1,056,422 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 40 Apprentice | | Apprentice Joined: Oct 2004 Posts: 40 | I was told awhile back that an early chevy car front drums will fit my 56 3200, is this true. I found a pair from a 56 chevy car that look good and are 5 lug. Thanks for the help
Kevin | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, it's true, just need to use the hubs as well, which fit the spindle and use the same bearings
Bill | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | The spindles are longer on a truck than on a 55-57 car. The drums will work but you will need the hubs from a 51-54 car. Fred
| | | | | Joined: Oct 2004 Posts: 40 Apprentice | | Apprentice Joined: Oct 2004 Posts: 40 | Thank you for your help everyone | | |
