2 members (Ponchogl, Hush), 67 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#398710 04/06/2008 10:12 PM
OK, here's the deal. I've been wanting an OD tranny for my 64 with the 230/3 speed on the tree. I know I could go with the T-5 but I don't want to cut the floors and not have it original. I got my info packet from GM the other day, and they say there was an option for the OD for my model, but it was only available with 4:11 gears(I have 3:73)and don'
t think that should be an issue. My question is this...what exactly is the correct Borg Warner unit I'm looking for? R-10 or the R-11? I have some friends that are involved with sprint car racing and have asked several of them to keep their ears open for the unit I may need, and leads are coming in, but I want to make sure I get the right unit to make the install go as easy as it can. I've been looking on the web and all through the search files, but can't seem to find the right info. There is just too much info out there, and all I want to know is which unit am I looking for? Any help would be appreciated. Thanks
Tramp
dj durant
More pix on Flickr
Tramp #398743 04/06/2008 11:35 PM
The SM 318/R-10 combo would be correct for a '64, but the SM326/R-12 is stronger and is full syncro. Both will work fine, I beleive that the later unit is a bit longer and may require a shorter driveshaft.
Bill Burmeister
LONGBOX55 #398882 04/07/2008 3:45 AM
Thanks Bill. Synchro is nice, but I'm used to not having it with the original tranny in it now. I'm not needing the stump pulling power, just want to get the RPM's down when I take it out to play.
dj durant
More pix on Flickr
Tramp #399035 04/07/2008 4:22 PM
Your 64 probably has the short tailshaft trans which is about 15" long. Both OD transmissions are 22" long. In this instance you will have to modify the driveshaft. The later Saganaw unit will require a fine spline front yoke and some tweaking of the shifter rods. Either one would work fine in your truck with the 3:73 gears.
Fred
Tramp #399036 04/07/2008 4:25 PM
You can usually find the OD transmissions on Ebay but be sure to find out the shipping cost before bidding. Unless it's close by, it will cost more to ship it than the selling price in the auction.
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
jfnar #399666 04/08/2008 9:34 PM
You'll also want to get a wiring diagram for the transmission. I went to the local library and found what I needed in an old Chilton's manual.
I found my R10 at a swap meet. Try digging around there, they exist but can be difficult to find.
