| | | Forums66 Topics128,079 Posts1,056,303 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 | Hi Guys, Once in awhile the 230 will sneeze thru the carb, you can smell something a moment later. I replaced points, plugs, cap rotor, etc. I checked the timing, and it was right at the last mark on the advanced side timing mark.
Other than the backfire thru the carb once in awhile, this engine has alot of power & torque!! TIA, David
My truck don't leak oil, it just marks its teritory.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Have you checked the plug wires? Try advancing the timing a little more. If it does it as you increase the throttle it may be a low float level or sticking power valve or weak accelerator pump. If it does it as you run along it is probably in the ign. system. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
