10 members (MickeyP, MRMEROTH11, Gdads51, TexasJim50, 2-Ton, Southerntruck, Ponchogl, JW51, Shaffer's1950, 1 invisible), 133 guests, and 2 robots.
Topics128,132
Posts1,056,378
Members48,441
#398414 04/06/2008 5:05 AM
Hi Guys,
Once in awhile the 230 will sneeze thru the carb, you can smell something a moment later. I replaced points, plugs, cap rotor, etc. I checked the timing, and it was right at the last mark on the advanced side timing mark.
Other than the backfire thru the carb once in awhile, this engine has alot of power & torque!!
TIA,
David
My truck don't leak oil, it just marks its teritory.
Riding in the Passing Lane
Have you checked the plug wires? Try advancing the timing a little more. If it does it as you increase the throttle it may be a low float level or sticking power valve or weak accelerator pump. If it does it as you run along it is probably in the ign. system.
1972 Chevy c10 Cheyenne Super
