9 members (55shaker, 1955 1 Series, BC59, 3800GUY, RaNfLaS, tclederman, Otto Skorzeny, wilbur53, FAST55), 156 guests, and 0 robots.
Topics128,104
Posts1,056,201
Members48,436
#398324 04/06/2008 1:41 AM
Changed 90 wt gear oil out of 4 speed . in 1960 c10. After I put it in I read the bottle, 90 wt boat lower unit gear oil. I don,t think this is anything to worry about ,or am I wrong?
Ken
Ken,
See if the label mentions GL-5 anywhere. I'm sure you are OK.
Stuart
Well it said something about gl 5 I will look at bottle to check. It was not a syn product.
Ken
p.s do you want gl5 or not?
The bottle reads exceeds API recommended GL5 levels.
It was Castrol Brand.I think its o.k.
Ken
It will be fine.
Paint & Body Shop moderator
should be ok.... ever spill any gear oil and had to clean it up.. that is some bad smelling stuff....
Redryder pix
My Hotrod
I believe the Lower Unit lube just has a few additives to make it extra sticky and displace moisture in a marine environment that is why it is more pricey than straight 90w.
Actually it is prob. a bit better than straight lube. I know a half a qrt. of Johnson lower unit lube for my bass boat is like $12.00, but I have to use or void my warrenty.
Tim
1952 Chevy Shortbed
Photos in Photobucket
