1 members (Gray_Ghost),
65
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 23 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 23 | I am looking for a two speed rearend instruction decal for the 57 6500 there is a very faint piece on the dash of the original I have plans to make this truck as new as it was when it rolled off the assembly in Janesville. I work for the railroad and this truck has put a new prespective on where things come from we work the GM plant in Doraville Ga. (Atlanta Ga.) its suppose to close this summer I want to take a tour of the plant before then. What happen to the plant in Janesville is it still there or not. Thanks Kip Parham | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | Check out Mongo's Garage for the decal. Cleon | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | The 2 spd. axle decal, is different on the '55-'59 Task Force trucks. | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | OOPS. I did not pay attention to the year. Cleon | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | What does the sticker for the post '50 truck look like?
Bruce | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I don't believe I have ever seen a decal for the Task Force turcks (55--59) and I own 3 with 2-speed rears. Anyone have one they can take a picture of? Thanks. Mike B  | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | The sticker on my 64 looks just like what Mongo has there the speeds are just a little higher and the lower right corner has the axle ratio in small print neither of my 56 nor my 57 have stickers.
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | The 2 spd. decal, that was on the '56 Chevy LCF, I had was on the inside sunvisor, had no color to it, & showed a picture of the selector on the gear shift. The one on the '60 Chevy LCF,I had, was pretty close to the same. Both these trucks had electirc 2 spd. rears. | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | What about on the '51-'54?
Bruce | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I've actually seen 4 different versions, of the '47-'55 1st series decal. One like the one Mongo has reproduced, another one almost identical to Mongo's, but with a different selector pictured, & two that were like the above, but had a transparent background. I'll try to find some pictures. | | | | | Joined: Mar 2008 Posts: 23 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 23 | My truck has a very light shadow of the decal its on the dash on the center from what I can tell the left looks alot the above replacement decal but the right side shows the gearshift with the 2spd knob Thanks Kip | | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | The decal on my '56 was a simple text instruction stciker on the back of the sun visor. I attempted to reproduce it as close as possible with my printer when I recovered the visor. I believe I still have the test around somewhere. So far haven't seen anything on the dash, but I haven't gotten to stripping out the old paint & gunk on the dash yet. 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | I have pictures of a couple in that year range at home, I'll try to track them down tonite and post em. MONGO | | | | | Joined: Mar 2008 Posts: 23 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 23 | That would be great I got my factory assembly manual today in the mail from Jim Carter and it shows the decal on the dash it even gives the part # Thanks I hope you can find them Kip Parham | | | | | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | This is the pic I had of that style. Hope that helps. Later 2 Speed StickerMongo | | | | | Joined: Mar 2008 Posts: 23 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 23 | Thats it how can we get some of these printed up any ideas I would take ten just to get them done Thanks Kip | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | I would like a couple too... | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Mongo if it helps that is the same as the sticker in my 64 also. | | | | | Joined: Apr 2005 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 37 | I will reproduce it s a decal, if anyone hasn't already.
Rob | | |
