2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#39766 10/02/2003 7:21 PM | Joined: Apr 2003 Posts: 15 New Guy | | New Guy Joined: Apr 2003 Posts: 15 | I am having a hard time finding any information and specs. on my 288 engine. The only v-8 I ever see any info on is the 332. If anybody can give me some direction it would speed up my progress. I am looking for parts for the distributor right now. | | |
#39767 10/02/2003 10:05 PM | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | I'm not so sure that the 288 is a Pontiac motor. I am sure it's a motor that GMC used.
The 288 V8 engine was used for a short period in the beginning of the "Y" series GMC trucks. "Y" series trucks are so called "1955 2nd series". In the latter of part of 1955 and all of 1956, GMC went to the 316 V8. | | |
#39768 10/02/2003 11:57 PM | Joined: Apr 2003 Posts: 15 New Guy | | New Guy Joined: Apr 2003 Posts: 15 | My VIN# is 1028PY7655 so I guess I have a 55 2nd series. I have always been told that the 288 was based on the Pontiac v8 platform. Sure it is not going to be exactly the same as the engines they would put in a pontiac car, but I don't really care, I just want some data specific to the engine I have. | | |
#39769 10/03/2003 7:07 AM | Joined: Feb 2000 Posts: 5,199 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,199 | My Pontiac history book list a 287.2 ci engine for 1955. It was the first V-8 for Pontiac's. The 7.4 compression ratio engine with 1 x 2 had 173 HP. The 8.0 compression with 1 x 2 had 180 HP, the 1 x 4 carb engine had 200 HP. Its a 3.75" bore and 3.25" stroke. In 1956 they went to a 316 CI engine. The book does not mention GMC. Joe | | |
#39770 10/03/2003 6:25 PM | Joined: Apr 2003 Posts: 15 New Guy | | New Guy Joined: Apr 2003 Posts: 15 | I need a parts book for this engine. What is the name of this Pontiac history book? I know the engine exists, but I have not been able to find any parts listings. | | |
#39771 10/04/2003 1:50 AM | Joined: Apr 2000 Posts: 71 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 71 | The 287 Pontiac used in the GMC is the same as the car motor, except when used in a large truck. Then they usually had sodium cooled valves. I don't remember seeing any in pickups, but there may have been some used. The ones I remember, were in trucks the size of 60 series Chevs. I don't know the GMC numbers. | | |
#39772 10/04/2003 3:38 AM | Joined: Aug 2003 Posts: 17 New Guy | | New Guy Joined: Aug 2003 Posts: 17 | What do you need for the distributor? I've got a spare. Vac advance is bad but I believe auto archives has additional nos advances. They sold me mine :http://www.automobilearchives.com. Terrill Machine, Rt 2, Box 61, DeLeon, TX 76444, PH: 254-893-2610, also has tons of Pontiac parts available. Their very reasonable especially compared to Kanter.
58 1 ton Napco 59 1/2 ton Napco 58 1/2 ton Napco 55 1 ton 9’ bed 58 3/4 ton stepside 55 LCF boom truck (3) 57 2 tons
#39773 10/05/2003 4:20 AM | Joined: Feb 2000 Posts: 5,199 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,199 | The book I have is just a coffee table book about the History of Pontiacs. All that is listed is what I posted. Try getting in touch with the POCI club or the Pontiac Historical Society. A 1955 Pontiac shop manual may be what you really need. Check some of the reproduction book companys. Joe | | |
#39774 10/05/2003 3:13 PM | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | MJV: You might search around for a GMC Master Parts Book, Models 100-450, Published 1958 or 1959 and covers Y, X, T, and, S series trucks. I am not aware of reprints of this book, but they might be out there.
I see them on eBay from time to time but it will take a fair amount of diligence to find one. It will be invaluable to you. | | |
