| | | Forums66 Topics128,113 Posts1,056,280 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2003 Posts: 16 Apprentice | | Apprentice Joined: Mar 2003 Posts: 16 | hey guys i have a 57 chevy 235. i am in the process of rebuilding the engine and i think im missing a oil tube.. i am looking at the lifter with the side cover off and there is a threaded hole that i think supplies oil to the rocker shaft. i am kinda remembering that there was a pipe that screwed into it.. can someone get me a picture or fill me into what i should be looking for.? or am i dreaming. thanks | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yes, there should be a line there, 1/8" diameter if memory serves. Been a while since I had mine apart. The line runs from the rear hole that you mention up to another threaded hole at the top of the lifter area, just below the deck surface. I don't have a pic for you, perhaps another 'Bolter will have one that can show you more clearly where it routes. I beleive that the line is available new from several of the suppliers listed on the links page.
Bill Burmeister | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Is THIS what you're referring to? | | | | | Joined: Mar 2003 Posts: 16 Apprentice | | Apprentice Joined: Mar 2003 Posts: 16 | Czechman- that is perfect. just what i needed.. thank you now all i need to remember is where i put the darn line.. thanks longbox.. i will be checking out the suppliers if i can't find the line..
