2 members (papas52, 2-Ton), 110 guests, and 2 robots.
Topics128,115
Posts1,056,292
Members48,439
#397555 04/04/2008 3:54 AM
Apprentice
Apprentice
hey guys i have a 57 chevy 235. i am in the process of rebuilding the engine and i think im missing a oil tube..
i am looking at the lifter with the side cover off and there is a threaded hole that i think supplies oil to the rocker shaft. i am kinda remembering that there was a pipe that screwed into it.. can someone get me a picture or fill me into what i should be looking for.? or am i dreaming.
thanks
Yes, there should be a line there, 1/8" diameter if memory serves. Been a while since I had mine apart. The line runs from the rear hole that you mention up to another threaded hole at the top of the lifter area, just below the deck surface. I don't have a pic for you, perhaps another 'Bolter will have one that can show you more clearly where it routes. I beleive that the line is available new from several of the suppliers listed on the links page.
Bill Burmeister
Is THIS what you're referring to?
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Apprentice
Apprentice
Czechman- that is perfect. just what i needed.. thank you now all i need to remember is where i put the darn line..
thanks longbox.. i will be checking out the suppliers if i can't find the line..
