7 members (Thomaslb, 1955 1 Series, Hanks custodian, Ridgeback, Hotrod Lincoln, Ponchogl, 1 invisible), 46 guests, and 2 robots.
Topics128,090
Posts1,056,031
Members48,433
#39658 05/23/2002 2:53 PM
A previous post described an occaisional difficulty getting my 4-speed into 3rd gear. Kedso said it could be due to excessive end play in the main transmission shaft. I have another symptom.
I use the granny gear for a parking brake on our slightly sloped driveway. When I depressed the clutch and moved the shifter to neutral, it stayed in gear. Does this also say "excessive end play?" Thanks!!
(We're leaving for the salt chuck for several weeks so I'll add the tranny advice to my to-do list.)
#39659 05/23/2002 5:10 PM
If your shifter feels kind of funny (SLOPPY OR NOT WANTING TO SHIFT)I would say you may have a worn end on the shifter or worn shift forks!
#39660 05/23/2002 9:45 PM
Junior Member
Junior Member
I have had 3rd gear problems in a past 4sd tranny of this nature. In my case it was a cracked 3rd gear synchro, (i.e. the toothed brass ring preceeding the gear). Maybe the cracked Synchro was the result of excessive shaft end play? I just replaced tranny.
#39661 05/24/2002 2:27 AM
Starts to sound more like wear in the shifter. Time to take the top off. You can get to that without pulling the trany. Just make sure you know how to get it back on.
if it dosen't need fixed, break it
#39662 05/24/2002 4:54 PM
Remember to never hang your hand (or any other weight)on the shifter,it will cause premature wear and you will end up with problems like this.
