| | | Forums66 Topics128,053 Posts1,055,777 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 23 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 23 | | | | | | Joined: Mar 2008 Posts: 23 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 23 | Well here it is I hope you all are seeing the pictures It took a while to figure that out I posted the other day. But yall wanted pics so here you are.I want to replace my cab I found another truck locally its 4400 V8 no 2 spd will it work on the 6500 the cab one 4400 is great the rest on truck is kinda rough I would have alot odd and ends to sell including the 283 to fund this project it also has what appears to be a factory flatbed and the spare rack is still hanging under the back Thanks Kip | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | That's a nice look'in truck. | | | | | Joined: Dec 2007 Posts: 58 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 58 | Good pictures. What is the knob between the light knob and the choke? | | | | | Joined: Mar 2008 Posts: 23 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 23 | Thats the PTO control for the dump | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | Good looking truck. What's wrong with the cab? | | | | | Joined: Mar 2008 Posts: 23 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 23 | The cab floor has a few rust holes which could be fixed the biggest problem is above the windsheild in the center the inside panel has rusted through and somebody put black tape over it | | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Nice truck thank you for the pictures | | |
