1 members (51sub), 128 guests, and 2 robots.
Topics128,125
Posts1,056,338
Members48,440
Hey guys,
I need some help. I have an original '50 1/2 ton 5 window. I'd like to upgrade the frame don't have the cash for a mustang II. A local guy has a '62 shortbed 2wd complete frame for sale for $150. How well would my '50 body bolt up to this frame? Could I run a small block and TH auto trans with it? any help would be great...especially from someone who's done this combination! Thanks!
A lot of mods required to do that swap.
The 62 frame along with its' torsion bar IFS is rare. Those "X" frames were only used from 60 - 62. That's why you don't see chassis parts/upgrades for trucks of those years in the vendor catalogs. Do a search for torsion bar suspension parts for those years and you will see. The mustang II seems cheap to me compared to what you would have to do to make that frame work w/ the tranny and motor you want to use.
Good Luck!
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
If you are tight on bucks AND if the frame is structurly sound, I'd use the original and just replace the worn parts and bushings. Get a dropped front axle and a lowering kit for the rear.
It doesn't have to cost a lot of money.
Replacing the worn parts in a 45 year old suspension could easily cost as much as the most economical Mustang II crossmembers.
Best thing to do to see how it'll fit is draw a detailed diagram and take measurements. If you do the frame drawing on graph paper and then do the 1950 body on onion paper (tracing paper), and make them to scale, it might make it easier to determine preliminary mounting points and where you'll have to weld up modifications.
I'd personally tackle this project this way. If you do the work yourself, you won't need a lot of money. The handier you are, the cheaper the project will be.
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
1 Offline
the track width is wider than the 50' and your front tires will stick out.
thanks for the info, guys. Glad I asked!
