3 members (Rich'sToys, dt235sd, BC59), 45 guests, and 4 robots.
Topics128,179
Posts1,057,157
Members48,465
I'm going to be switching from 6 to 12 on my 53 3100. The only question I have is about the aftermarket turn signal. Does it have to be 6 or will 12 work fine?
It's a Signal-Stat Sigflare 900.
Thanks, Spencer
you just need to use a 12V flasher, the control and wiring don't matter
jdl Offline
You have the same model as mine, and as he said, it will be fine. As someone here put it when they told me, the turn signal is only to direct current.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
Riding in the Passing Lane
Some have a pilot light in the switch. The bulb would need to be changed.
1972 Chevy c10 Cheyenne Super
jdl Offline
If I'm not mistaken, since I have the same model, there's three very small lights in the signal indicator. I didn't know if they had to be changed or not.
Jordan D. Long
Photobucket
