| | | Forums66 Topics128,005 Posts1,055,255 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | I've done a search and haven't found this particular problem. Don't know if it's engine or electrical, so here it is.
My truck won't start unless it is pulled. The starter won't spin it fast enough. Checked and cleaned all connections, replaced starter with a fresh unit, same thing. Jumped a weak 12V directly into starter, ground to engine(stock '51 216, 6V), and it still doesn't turn fast enough. Bump-start it and it stokes right up.
I am mystified. 1951 3800 Be the change you want to see. -hotshoe
| | | | | | OLTrucks Unregistered | | OLTrucks Unregistered | My first thought is "do you have a new battery cable?" If so is it a for 6 volt systems or a 12 volt from off the shelf. 6 volts need more amps so the cable is a tad thicker. | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | Not it. The old cables are still in there, apparently okay, ends clean. When I jumped, I bypassed all that as described above. After dinner I'm gonna put a fresh, charged 12V on it and see what happens.
| | | | | Joined: Nov 2007 Posts: 3 New Guy | | New Guy Joined: Nov 2007 Posts: 3 | What are your compression readings? Anything less than 100 psi, it is difficult to start. 125 to 150psi is much, much better. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | hotshoe36,
You have certainly done the right things so far. The obvious choices would be it isn't turning fast enough OR it can't turn fast enough.
It seems to me you have ruled out the electrical end of things by installing a new starter, then jumping the rig with a 12 volt battery. If all was well, that should have make it spin like crazy.
The next thought would be that some mechanical issue is binding the engine up. If this were the case, you would probably see the effects of this problem as you ran the engine for awhile.
I would pull the gravel pan when the engine was cold and see exactly how much oink it takes to turn it over. You indicate it's an old 216 which, with the plugs pulled it should turn easily with the fan.
Back on the electrical end of things, you could have received a bum starter, or your cables could be too small or failing at the terminal (internally).
Did the truck run fine..then this problem popped up! Scout around a bit more. See if the engine is tight for some reason and resisting the new starter.
My bets are with the starting system, not a mechanical problem. Your battery, cables, connections and starter all must be sound for this thing to spin over nicely. Keep us posted
Stuart | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | I'm out of time. One good thing about being a semi-retired truck is that you can wait until the guy gets a round tuit. Remember those? Anyway, I have a 2:30 am wake up, because I am emphatically not retired. More before too long.. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | Moron, me. After a 15-hour work day I got back to Epic #2 just before dark. Tried turning the engine by hand - atomarc's suggestion - and drew a deep sigh of relief when it turned, plugs in, by tensioning the belt and pulling on the fan. Hooked up my certified number one finest kind 12V battery, one of two in this little unit, [IMG]http://thumb11.webshots.net/t/63/463/5/34/34/2467534340096215731LCZagQ_th.jpg[/IMG] and goshdarnit if she didn't stoke right up! So I don't actually have any problem at all except maybe a bad cable and a severe dearth of meckanical skill, say, of the kind which might have made me wonder if a 12V battery with a dead cell, which had been sitting in my garage for over a year and had not been charged, but showeed 11V on my multimeter, might in fact not have had as much oomph on tap as my truck's 6V battery.. Go, now. Hide face. Right after reconnecting the return spring on the starter pedal so the motor doesn't stay engaged and make rude noises at me.
| | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | Hey Hotshoe....It happens to the best of us.... Its best if you hide that ugly mug of your's.....  you coming to 3B's on the 26th????Dave | | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | Did you correct the problem? If not, the ignition switch is a good suspect. On a 6 volt system, there is no start-bypass circuit, so if the ignition switch has resistance, the coil gets low voltage and reduced current. Remember, those old engines can be started with a hand crank; that cranking speed is much slower than the worst starter- as long as the engine cranks at all. Since you say the engine starts almost immediately with a push, I suspect the ignition switch is at fault.
Harvester | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | Dave, thank you. I resemble that remark.
Harvester, problem solved. A bit embarrassing, as it was something more than a little simple, as you'll see if you read my last. 1951 3800 Be the change you want to see. -hotshoe
