6 members (Tronman, Gray_Ghost, electors, Otto Skorzeny, Bill Hanlon, klhansen), 190 guests, and 3 robots.
Topics128,041
Posts1,055,490
Members48,424
I'm having problems starting my 1950 216. It was running fine, i drove it around and everthing but then it just died. Now i've been looking it over and i do have spark, in fact, when i pour gas into the carb it will run for a few seconds until that gas is burned up. So im assuming that its a fuel delivery problem. I opened the fuel line where it comes out of the pump and turned it over to find there was fuel coming out. however, when I cranked it with the fuel line open at the carb...nothing. Is it possible to have fuel coming out of the pump but not have the pressure to reach the carb? Also, could this just suddenly happen as it did? Maybe this seems like a pretty basic question but it's got me stumped. Thanks for your help in advance.
Red dot, center of chest ...
Is it possible? Yes, if there's an obstruction in the line. Take the line off between the pump and the carb and see if you can blow through it. Do you have an inline fuel filter on it? If so, it may be clogged.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
You may also have bad fuel pump and it may be dumping fuel into your oil pan. Pull the dip stick and smell the oil. If it smells like gas change the pump and change the oil. While you are at it blow out or change the fuel lines and install a fuel filter at the tank to catch any debrie that may be in there. Good luck!
Brian
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
Has this truck been sitting long?
It may be something as simple as a blockage at the float needle in the carb(like silicone that someone used to seal a fuel sending unit in a truck I bought) grin I couldn`t figure out where the chunks were coming from that kept stoping my 53 I had.I found the previous owner used blue silicone to seal the sender unit in the tank! eek
It breaks down in fuel! grin
