0 members (), 102 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#395569 03/31/2008 12:09 AM
Been thinking about picking up a big bolt to use for a hauler for my street/strip car. It's 45 miles to the track and I'll be in big trouble if I ever blow anything up. I have been picturing a long wheel base TF 2 ton, using a flatbed off of a more modern hauler with all the tilt stuff. Is this feasable? Haven't found a truck yet, just tossing around ideas. Car weight is approx. 3200 lbs.
Devin
If you can't hose it out it ain't a truck
55 3100
63 Corvair Monza
64 El Camino
72 240Z
01 Suburban
55 tractor #395605 03/31/2008 1:00 AM
V
V Offline
As long as you don't plan to get there or get home in a hurry.
Sure its possible. There is an AD Chevy car hauler I see at local shows. I've photographed it several times and realized the second time that I never shoot the car, just the truck.
These are NOT dialup friendly photos.
AD Car Hauler. AD Car Hauler
There are several more pictures of it at Hot Rod Arama show pics starting with 100_3503.jpg. I know I took more pictures of it at another show, but couldn't find them quickly.
OldSub #395659 03/31/2008 2:40 AM
62401
A friend of ours here in our local ATHS Chapter has a '52 Ferd 2-ton with it's original drivetrain that he's completely restored and had Chevron mount a rollback body on it. It works great -- we convoyed with him to Winchester, VA for the show there when he was hauling his Model A truck on the back and he only slowed down some on the big hills. He might have put different gearing in the rear end.
Here's a picture of it
Not that you need to go buy a new custom set up from a major manufacturer, just showing you that it's feasible without going crazy with the drivetrain. If you'd like to ask him about it, just pm me and I will put you in touch with John.
Regards,
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
John Milliman #395709 03/31/2008 4:40 AM
I figure the speed can't be much worse than 4.56s behind a big block. 65 is really way too much for long distance travel, 55 is ok, it's only about 3200 rpm. If I do this right I can also use it on other weekends for hauling rocks, gravel and dirt for yard projects with some sideboards.
Devin
55 3100
63 Corvair Monza
64 El Camino
72 240Z
01 Suburban
55 tractor #395736 03/31/2008 6:16 AM
Vannatta is still running the six cylnder in it I would guess, he needs to change it out to a hot rod Lincoln.
Thanks for working with him on the web site for ATHS John.
ABento #395802 03/31/2008 2:42 PM
I'm currently working on a'49 6400 grain dump truck that I intend to use for a car hauler. I have been watching for a used rollback unit. I have not seen many as I belive the beds are put back on new trucks when the truck is replaced. I will probably extend my 13 ft bed to 18 feet and use slide out ramps and winch the towed vehicle on to the truck.
Cleon
1949 Chevy 6400
1931 Chevy Firetruck
31,32,33 #396079 04/01/2008 1:55 AM
Hello 55,check out my truck in the Gallery,48 chevy 2ton with 1ton front axel and Dana 70 rear.It's got a tilt bed and winch.
Floyd
_____________
Floyd
If we choose being kind over being right,we will
be right every time.
Knowledge is a poor substitute for experience.
Remember what is precious to another, may not be to you, but it
is precious nonetheless.
1948 Chevy 2-Ton
tntrucknut #396316 04/01/2008 5:20 PM
I have been considering using a mobile home frame I have to make a long trailer. A tow/recovery friend of mine said that(at least in Texas) I wouldn't have to worry about CDL/commercial registration/comm. insurance. He said that as long as the car isn't on (or attached physically to) the truck, it's like having a pickup and a utility trailer.
I love the idea of putting a roll-back on a 2-ton, and I have often thought about doing so. I am not a tow driver(except my own private tasks), but I was worried about finding that one state trooper that wanted to write every ticket he could think of.(Murphy's Law)
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
