| | | Forums66 Topics128,024 Posts1,055,390 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | Been thinking about picking up a big bolt to use for a hauler for my street/strip car. It's 45 miles to the track and I'll be in big trouble if I ever blow anything up. I have been picturing a long wheel base TF 2 ton, using a flatbed off of a more modern hauler with all the tilt stuff. Is this feasable? Haven't found a truck yet, just tossing around ideas. Car weight is approx. 3200 lbs.
Devin
If you can't hose it out it ain't a truck
55 3100 63 Corvair Monza 64 El Camino 72 240Z 01 Suburban
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | As long as you don't plan to get there or get home in a hurry. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Sure its possible. There is an AD Chevy car hauler I see at local shows. I've photographed it several times and realized the second time that I never shoot the car, just the truck. These are NOT dialup friendly photos. AD Car Hauler. AD Car Hauler There are several more pictures of it at Hot Rod Arama show pics starting with 100_3503.jpg. I know I took more pictures of it at another show, but couldn't find them quickly.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Nov 1995 Posts: 5,714 Bond Villain | | Bond Villain Joined: Nov 1995 Posts: 5,714 | A friend of ours here in our local ATHS Chapter has a '52 Ferd 2-ton with it's original drivetrain that he's completely restored and had Chevron mount a rollback body on it. It works great -- we convoyed with him to Winchester, VA for the show there when he was hauling his Model A truck on the back and he only slowed down some on the big hills. He might have put different gearing in the rear end. Here's a picture of it Not that you need to go buy a new custom set up from a major manufacturer, just showing you that it's feasible without going crazy with the drivetrain. If you'd like to ask him about it, just pm me and I will put you in touch with John. Regards, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | I figure the speed can't be much worse than 4.56s behind a big block. 65 is really way too much for long distance travel, 55 is ok, it's only about 3200 rpm. If I do this right I can also use it on other weekends for hauling rocks, gravel and dirt for yard projects with some sideboards.
Devin
| | | | | Joined: Jan 2008 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 165 | Vannatta is still running the six cylnder in it I would guess, he needs to change it out to a hot rod Lincoln. Thanks for working with him on the web site for ATHS John. | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | I'm currently working on a'49 6400 grain dump truck that I intend to use for a car hauler. I have been watching for a used rollback unit. I have not seen many as I belive the beds are put back on new trucks when the truck is replaced. I will probably extend my 13 ft bed to 18 feet and use slide out ramps and winch the towed vehicle on to the truck. Cleon | | | | | Joined: Apr 2005 Posts: 187 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 187 | Hello 55,check out my truck in the Gallery,48 chevy 2ton with 1ton front axel and Dana 70 rear.It's got a tilt bed and winch. ----------- Floyd
_____________ Floyd If we choose being kind over being right,we will be right every time. Knowledge is a poor substitute for experience. Remember what is precious to another, may not be to you, but it is precious nonetheless. 1948 Chevy 2-Ton | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | I have been considering using a mobile home frame I have to make a long trailer. A tow/recovery friend of mine said that(at least in Texas) I wouldn't have to worry about CDL/commercial registration/comm. insurance. He said that as long as the car isn't on (or attached physically to) the truck, it's like having a pickup and a utility trailer.
I love the idea of putting a roll-back on a 2-ton, and I have often thought about doing so. I am not a tow driver(except my own private tasks), but I was worried about finding that one state trooper that wanted to write every ticket he could think of.(Murphy's Law) | | |
