2 members (Otto Skorzeny, baldeagle), 114 guests, and 2 robots.
Topics128,037
Posts1,055,467
Members48,424
#394977 03/29/2008 6:28 PM
Anyone installed a trailer hitch on there 50's truck< for light towing
ryanb790 #394988 03/29/2008 6:53 PM
I put one one my 52 1 ton, and then moved it to my 48 2 ton.
I called all the hitch manufacturers and they all said "we don't have one". So I asked if they had one for something with a 36" outside the frame rails measurement, still nothing. They did say I could use an "RV" type hitch that is adjustable.
Then I went to the local trailer hitch place who has a tractor trailer load of new hitches, pick any one you want and they are all the same price. The plan was to find something suitable that I would cut and weld as needed, ended up finding a perfect bolt on hitch.
Best you can do is take a tape measure and go looking in a junk yard or at a place that installs hitches.
I doubt that the hitch I used would work on your 1/2 ton frame, as it is different than mine.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #395118 03/30/2008 12:10 AM
For what it is worth. I was rummanging around in the bed of an abandoned 49 3/4 ton. There was not much left, but I came away with the screw jack, lug wrench, and a bumper hitch. From what I have found out it clamps to the bumper. It sorta looks like a c clamp with a flange to attach a ball. I sandblasted it and painted it Chevy orange. And yes I plan to find a 50s camp trailer to restore and pull behind the 52. Unsafe? yep, But if I was worried aboute safe I would drive an Audi. LOL.
Jimmie D #395191 03/30/2008 2:26 AM
Leo Offline
Moderator
Moderator
Up here, you are not allowed to weld on a hitch, don't even think a home made hitch is allowed either. We have to get our trailers and tow vehicles inspected every year.
Leo #395308 03/30/2008 11:39 AM
im customizin a class 2 hitch to fit on my truck with some xtra support bars to the frame crossmember ...so I can haul my bassboat to the local lake, only. it is a nice easy ramp, most other lakes I fish the ramps are either so steep or in such bad condition that I have half the drivers seat sucked up my arse hopin I dont sink the Rig, that I dont back in unless the Ol Dodge is in 4 wheel.
So the Bolt will haul to the local lake only!...but will be good to go haulin a decent size trailor on the road.
1952 Chevy Shortbed
Photos in Photobucket
SW_Radial #395316 03/30/2008 1:04 PM
I fabricated my own heavy duty trailer hitch for my 54 truck and the install was basically about the same as for a Reese-style hitch. With the extended insert and 2-1/8" ball I've yet to pull a trailer, but I've noticed that drivers for some unknown reason, seem to stay MUCH FURTHER away from my back bumper!!!!!
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
Here is a picture of the trailer hitch I found that bolted to my AD 1 and 2 ton trucks.:
http://rides.webshots.com/photo/2970880650080251109semNwf
And one of the hitch not bolted to the frame, right side of the picture:
http://rides.webshots.com/photo/2858777480080251109QvHMaJ
It bolts on with two bolts per side behind the rear spring hanger, and one per side in front of the spring hanger.
Grigg
---All pictures---
Grigg #395419 03/30/2008 6:27 PM
Avette4me #395434 03/30/2008 7:23 PM
Draw-Tite website only goes back to 63. 55 on up have a 34" frame width, which is pretty universal as far as the hitches go. 54 and earlier half tons have a frame that is tapered from front to rear, and is about 46 inches wide in the rear. Some level of modification generally needs to be done to come up with a suitable hitch. You may try to find the widest hitch you can, and cut it down to fit as needed.
I saw a F@#d Expedition parked by my house. I just happened to have a tape measure handy and noted that the hitch was 50 inches wide, with the square tube going through the mounting brackets. That would work on an AD truck with very little modification... grind weld away from tube, enlarge opening in bracket to reweld the tube at a slight angle to match frame, weld, paint, bolt on.
This reminds me of the hitch I put on my '51 Chevy car in about 1962. It was designed for the '51 and attached to the back of the bumper with a bolt. I had to get a hole cut through the bumper with a torch. It also attached to some cross piece between the frame rails. I pulled a plywood Sande Ace runabout with it.
I'll be putting a hitch on my '48 3/4-ton some day but those frame rails are really far off the ground.
When I was looking for a hitch for my CJ-5 I found one that was a universal fit- It had a bunch of pieces that all bolted together to fit pretty much any frame width, and it fit pretty well. I wish I would have kept it, I haven't found another like it.
My truck came with an old hitch that seemed to be made for it, but its not a receiver hitch, it has a little bracket that bolts to the rear bed crossmember and another part of it bolts to the frame, and it has a tongue that fits over the top of the bumper. The only problem is that it is too high for most trailers.
Paint & Body Shop moderator
Jim & Caroline
