4 members (Gdads51, MickeyP, TUTS 59, Otto Skorzeny), 23 guests, and 5 robots.
Topics128,013
Posts1,055,312
Members48,419
#394967 03/29/2008 5:54 PM
Is it reasonably safe to weld on the rear axle tube to put shock mounts on? I mean as far as the welding stresses on the metal. I am working on a '34 half ton. And do I really even need shocks on this old truck?
davy #394971 03/29/2008 6:07 PM
Davy, I have NOT worked on a 34 but I think its like a 37 but maybe not.
Anyway, if its like I think it is there should be a plate under the springs that the U-bolts go through. Why can't you make a plate with a bolt welded to the back of it for one end of the shock to go on....and for the top weld a small bar across the chassis with a long bolt welded to it for the top end of the shock to go on. This is what I did on my 37 and it works nice and without a lot of money.
To answer your specific question I see no reason you could not weld to the axle housing. Most folks have to weld new spring perches on rear ends all the time without problems. I think you would be fine as long as you don't "burn through" the housing.
I'm sure others will chip in with their comments.
davy #394974 03/29/2008 6:13 PM
davy,
I wouldn't hesitate for a second to weld a shock mount on a axle housing. The weld will outlast all of us and will do no structural or metallurgical harm.
Bust out the AWS 7018-Atomarc! grin grin
Stuart
Achipmunk #395092 03/29/2008 11:15 PM
Nice looking-rather, great looking pickup achipmunk. And thanks for the advice--I could use either one--thanks. Thanks for the backup on that , Atomarc
davy #395213 03/30/2008 3:03 AM
I have all four of the original shocks off my 37 I wont be using,they do need to be rebuilt. Jeff
Jeff Ogden #395223 03/30/2008 3:34 AM
I will probably just use modern shocks I guess--My truck seems not to have had any shocks--as far as I can tell.---Thanks
