2 members (dunfire, Wayne67vert), 93 guests, and 1 robot.
Topics128,129
Posts1,056,360
Members48,441
#39500 06/16/2003 6:49 AM
From what I have been hearing, the engine block number should match the number on the door post right? Where would this number be on a 305 V6? I have heard it is somewhere near the distributor, or is that just for the I6 engines? I know there is a number near the front of the engine just below the passenger side cylinder head, but I dont think this is the one I am looking for. Can anyone clarify this fer me?
P.S. The GMC V6 Kicks [censored]!
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht-
Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
#39501 06/16/2003 7:13 AM
I-6's on surface by the distributor. ON V-8's it is stamped on the part of block that sticks out past the pass side (right) head. I don't know on V-6's like yours, but that may be good choice. May have some letters and then numbers, which are a date code. Letters tell year, vehicle it's in, and trans usually used or carb maybe. You'll need a chart for the codes from somebody or dealer.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
