9 members (GMCJammer51, Materman, Lightholder's Dad, Ridgeback, Brian Moore, tclederman, jupitor, treegrower, 1 invisible),
189
Mod | | | Forums66 Topics128,080 Posts1,055,952 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#39494 04/13/2002 10:42 PM | Joined: Aug 2001 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 78 | Sorry if this doesn't have to do with stovebolts but hopefully someone can help me out. I just bought an '80 buick lesabre for a demolition car. It has a recently rebuilt small block(non-original) with a rochester 1 barrel carb. The guy I bought it from thought it was either a 350 or 307, but wasn't sure. Does anyone know what this engine could be? It just looks like a typical chevy small block but I've never seen one with a 1 bbl carb before. Thanks.
----------------------------------- Rollin' Hard 1946 Chevy 1/2 ton 1959 Phord 1/2 ton 2001 Chevy 1/2 ton
#39495 04/14/2002 12:17 AM | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | The only 1bbl carb V8 GM ever made was in 1933. I can't imagine that a 1bbl Rochester could even keep a V8 idling, much less get something moving. Small blocks came with 2bbl and 4bbl Rochesters. | | |
#39496 04/14/2002 12:31 AM | Joined: Aug 2001 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 78 | Well now I'm really confused. I am 100% POSITIVE this is a rochester 1 bbl and a GM small block. Anyone?
#39497 04/14/2002 1:02 AM | Joined: Apr 2002 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 146 | I've seen those in junk yards. They were in light commercial trucks. You need to find the casting numbers to ID the size.
if it dosen't need fixed, break it
#39498 04/14/2002 7:32 PM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | Paul is very correct on this one. One barrel Rochesters are on sixes, but I seem to recall something like what you are speaking of but would bet that that carb is a two barrel. I will say- anything is possible- but a one barrel on a V8? Not good. Why would you do it? Get some numbers off from the motor and the carb. We can help you more with that info..
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
#39499 04/15/2002 6:18 AM | Joined: Apr 2001 Posts: 8 Member | | Member Joined: Apr 2001 Posts: 8 | Well, the Rochester 2-jet has the same inlet size as the one barrel "B", and is smaller externally than a Holley 2bbl. What's the intake look like?
6 > 8
-Keepin' Things Inline-
