10 members (Shade Baby, klhansen, cmayna, Rusty Rod, David Bush, greenie-reddy, Cosmo, Lightholder's Dad, Peggy M, 1 invisible), 58 guests, and 2 robots.
Topics128,074
Posts1,055,913
Members48,429
#391742 03/22/2008 11:48 PM
i have ordered a new trailer to haul my treasures on. it will be hauling and loading from 3100,s to 6400,s. so what would be a good brand of winch and what #,s of pull?
believe it or not but some of the stuf i have and find to haul home does not run and may be settled in the mudd a little. lol
thanks for the help.
http://www.flickr.com/photos/11977495@N06/sets/
1952 COE
1952 3100
1953 3100
1950 6400
1951 Suburban
I've been hauling junk cars for a couple of years now that scrap metal has been so high. I pull a 18' car hauler with a Warn 8274 double lined. I pull a lot of cars that don't have any wheels and some have the axles buried. Two things I can recommend are a good hot battery and a good bumper jack. The life of the winch is the battery and the double line helps that out and if you can get the axle out of the dirt(bumper jack) it will help the life of the battery as well. I mounted the winch as high as possible on my trailer to give the "lift" factor when pulling. Hope this helps. Btw, I've never went to get a vehicle and left without it!!
GOD is good, ALL the time!
I have a Ramsey model RE-12000 (12,000 lb cap) mounted to the front of my 53 wrecker. As mkmiller stated, a good hot battery (or two for lots of amps) and a good snatch block for a double line will help you out. Check out www.awdirect.com .They have good products and they will stand behind them. Stay away from the cheap China junk.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
Houston54
Unregistered
Houston54
Unregistered
If what you will be winching are rollers then a Superwinch 4500 should be more than adequate and does not weigh a ton as some of the heavier units do.
There are pics of the installation of my Superwinch 4000s on the following link. It is not a recover type winch but if it rolls it will pull it up with little effort.
http://www.picturetrail.com/gallery/view?p=999&gid=17487588&uid=2902753
#392951 03/25/2008 3:29 PM
Houston54, nice set up. That trailer is low for easy loading and transporting. The deck of my flatbed is 4.5 feet high and can be a problem at times.
Wanted Good Woman:
gtow69 #394859 03/29/2008 10:40 AM
62401
For what it's worth, a few years ago I got to the point where I was sick and tired of fighting with come-alongs so I treated my self to setting up my trailer right. here are a couple shots of my set up
It's a 9,000 lb Superwinch that I can mount on the front of the gooseneck with a receiver hitch I had my Mennonite welder neighbor install for me. Heaviest thing it's pulled up on the trailer is a dead '50 Mack pumper truck. She creaked and groaned, but she got it up on the trailer (I used the snatch block!).
Moving equipment for my Mennonite neighbors has more than paid for both the winch AND the trailer.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Moderated by  MNSmith
