1 members (Otto Skorzeny), 81 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#394618 03/29/2008 1:25 AM
So on my other post someone mentioned that you can swap out the differential from a 70s rear into my 52 Chevy 1 Ton rear. I was looking for clarification of this. Is this a direct swap. nothing else needs to be changed, like the entire rear? I have never dealt with rears other than to just swap them out.
I am very interested in knowing if this is a direct swap.
Thank you
Jackyl #394622 03/29/2008 1:28 AM
The 3rd memeber will swap up to the '72 model year. It is a direct swap.
Bill Burmeister
Is the 1 ton rear on the 52 the same as the half ton?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
No.
Bill Burmeister
Ok so any particular truck? does it have to be a 1 ton? and this should solve my highway speeds issue then?
Thanks for all the help.
Jackyl #394715 03/29/2008 3:06 AM
What you want to look for is the '68-'72 3/4 ton, 350 w/automatic. Most had 4.10 gears. If you get lucky (and these are very rare, I've only seen 1 myself) you might find a '72 with the 3.54 gear.
Bill Burmeister
