1 members (baldeagle),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | So on my other post someone mentioned that you can swap out the differential from a 70s rear into my 52 Chevy 1 Ton rear. I was looking for clarification of this. Is this a direct swap. nothing else needs to be changed, like the entire rear? I have never dealt with rears other than to just swap them out. I am very interested in knowing if this is a direct swap.
Thank you | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The 3rd memeber will swap up to the '72 model year. It is a direct swap.
Bill Burmeister | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Is the 1 ton rear on the 52 the same as the half ton? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
Bill Burmeister | | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | Ok so any particular truck? does it have to be a 1 ton? and this should solve my highway speeds issue then?
Thanks for all the help. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | What you want to look for is the '68-'72 3/4 ton, 350 w/automatic. Most had 4.10 gears. If you get lucky (and these are very rare, I've only seen 1 myself) you might find a '72 with the 3.54 gear.
