| | | Forums66 Topics128,157 Posts1,056,887 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 18 Apprentice | | Apprentice Joined: Jun 2006 Posts: 18 | The casting code is B57848850. Motor is in a 1959 Chevy Apache truck. I pulled that number on the passenger side in front of the distributor. I have searched the net to match the code but cant find a match. Its a straight six.
Any help would be great!! | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Did you get a good read on the numbers?
My casting guide says the number should be seven digits between 37701488 and 3836848. I'm not that familiar with 235s, so maybe theres is another number and someone will chime in.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Brian - the casting number is actually cast into the block, and as Larry says, will start with a 3 .... if those numbers were stamped into the small machined pad near the distributor, they'll most likely be a rebuilders number, as it's not the pattern used from the factory
Bill | | |
