1 members (walterhvogel), 87 guests, and 3 robots.
Topics128,035
Posts1,055,559
#394120 03/28/2008 1:10 AM
Apprentice
Apprentice
OK I give up. I have a 52' 3100 that I have been working on. It may sound like a stupid question but how do you remove the weatherstrip on the inside of the door. It is the strip attached to the cab. Is it screwed in or what. Help
westerman
52' CHEVY 3100
westerman #394131 03/28/2008 1:37 AM
I think it's glued. If your not saving it.....give it a yank. grin
Bruce
My Trucks
Stuff I Collect
Ex Hall Monitor
Ex Hall Monitor
Nearly all vehicles are glued at least part of the way around. Some have push in clips in areas either way you won't be able to save it. You might be able to soften the grip of the glue with a hair dryer.
Tiny #394169 03/28/2008 2:31 AM
It's glued, good luck getting it off without destroying it.
EDIT: I didn't read the whole post. Tim is correct.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Czechman #394302 03/28/2008 9:16 AM
It sounds like you are referring to the cab windlace - the weather-seal strip that is attached to the cab, inside the door opening
It is slid into the retainer/track (1959 onwards) and is not normally glued in the track (the track was pinched in a few places after the windlace was positioned tightly in the track).
If this is what you are referring to, you will not be able to save it. It can either be pulled/ripped out of the track or cut out (run a razor or knife through the seal, along the track/retainer).
Tim
tclederman #394330 03/28/2008 1:31 PM
Yes you will probably have to break it up to get it out of the track it's been in there 56 years and probably hard as a rock. I'm facing the same situation on my '49.
Cleon
1949 Chevy 6400
1931 Chevy Firetruck
tclederman #394882 03/29/2008 2:28 PM
Apprentice
Apprentice
Thank you that was it. It is slid into a track. Now I'm wondering how hard it is to slide new stripping back in. I guess I'll cross one bridge at a time.Thanks again
westerman
52' CHEVY 3100
westerman #394895 03/29/2008 3:05 PM
westerman,
Do a search on "windlace" and you will find good explanations on how people have successfully installed the windlace (and good suggestion on combinations of strong words that help during the process).
Two suggestion after cleaning the track and before painting it:
1. Un-pinch the places where the track had been pinched.
2. Run a 12" piece of un-lubricated windlace through the track to make sure you'll be able to run the windlace through after painting.
When installing the whole length of windlace, people suggest using a lubricant, and my preference for use with any rubber part is a non-soap-based, non-petroleum-based lubricant. K-Y jelly is a name brand but there are many less expensive store-brands (water-based, water-soluble personal lubricant). They clean up easily and the residue hurts nothing. These type of lubricants also do not contain silicones (a substance that should not be used around painted surfaces or paint shops).
Finally, I think the 47-54 Factory Assembly Manual suggests starting the installation of the windlace at one of the breaks in the track near the top of the door. You then "thread" the windlace in two directions but it only have to travel about half the length of the track in each direction.
Tim
