| | | Forums66 Topics128,165 Posts1,056,987 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 54 | I need the "bulb holders and attached wires" for a 12 volt conversion for the dash/gauge lights for a 47-53. Anyybody know where to get 'em new? Thanks, regmudd | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | regmudd,
Is something missing? Aren't there existing bulb holders you can install 12 volt lamps into?
Stuart | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Your originals should work just fine. 12v bulbs will work just fine using 6v wire.
| | | | | Joined: Jan 2006 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 54 | My wiring is about shot. I'd like to replace everything and avoid trouble for the a long time if I can find replacement stuff. I have the existing stuff but again it's pretty worn. regmudd | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | regmudd,
If you have the lampholders but want to replace the old wiring, it is possible to dink around with the pigtail and install a whole new wire clear up to the little crimped lampholder
I thought the lampbase consisted of a Micarta disc with the brass nubbin the wire was crimped into. This shouldn't be impossible to re-invent with a new wire and a little ball of solder.
I wouldn't be surprised if new pigtails, even in the smaller size, weren't available. They would have to be spliced, but they would be new...just some thoughts.
Stuart | | | | | Joined: Jan 2008 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 77 | You can get them really cheap at Rhode Island Wiring supplies. Alot of different suppliers will have them. You can buy the complete sockets with new pins or just the wire pigtails with the phenolic washer and spring. | | |
