2 members (J Lucas, JW51), 266 guests, and 1 robot.
Topics128,081
Posts1,056,074
Members48,434
#393811 03/27/2008 3:22 AM
U
Apprentice
Apprentice
U Offline
I fired my 235 that I built for my truck today. I put a hydraulic cam from a 261 in it thinking it would give a little boost and still idle smooth. Well the smaller displacement must make the cam feel bigger because it idles with a considerable lope. The carb is all good and vacume at idle is 15",and wow is it responsive even a little to jumpy for a daily driver mabey. Has anyone experienced this ? A 261 hyd. is 222 deg. at 0.50 right?
I suffer from ADAD (Advance Design Acquisition Disorder)
I thought 261's had mechanical cams, at least the stock grind since it was used exclusively on trucks. If correct is this an aftermarket cam?
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
In Canada the hydraulic 261 cam is more common as there were many more Pontiac cars with the six than big trucks.
You Tube
knuckle head
knuckle head
A 261 cam ,solid or hydraulic is no where near 222 degrees duration at .050 lift.The Howards M4F ,206 degrees duration at .050 lift is slightly hotter than a mechanical stock 261 cam which I believe is around 190-200 degrees at .050.Factory cams were usually rated at .004 lift,the "advertised duration" giving far longer duration figures than .050 lift.
235's with a 261 cam have a barely noticable lope to the idle,sounds like you have some other issues contributing to the racey idle.15 inches of vacuum is low even for a typical 3/4 cam.
U
Apprentice
Apprentice
U Offline
The cam is a Canadian hyd. Pontiac 261. I drilled the idle air bleed in the carb and it smoothened out alot. Still has a little lope to it. It just needed a little more fuel at idle and off idle i guess. 15" is pretty good when you live at 4000ft above sea level.
IT SOUNDS LIKE YOU MIGHT BE A GOOD SOURCE OF WHAT SOME OF US
DOWN HERE ARE LOOKING FOR; A TRUE 261 HYDRAULIC CAMSHAFT WITH
LIFTERS. WOULD YOU BE WILLING TO GIVE US A CONTACT FOR SUCH
AN ITEM. THANKS...
U
Apprentice
Apprentice
U Offline
I think Canadian supplyers like Elgin have long since stopped grinding replacements. The ones I have are used ones Ive held on to, I think there arent that many around anymore. My cam grinder could probably make one for you. I measured my spare today It has .352" lift at the lobe. Im not sure of the dur. but 204deg rings a bell.
My FLAPS tells me he can get both the solid and hydraulic grind. When GM engineers put a 261 cam in a 235 they also added a cast iron dual exhaust manifold along with a 3 carb sidedraft intake. Does your engine have similar breathing characteristics?
You Tube
U
Apprentice
Apprentice
U Offline
Its just got stock manifolds with a Carter for a Can. 261 on it right now. I will swap my home built headers and triple Offy intake on once its broke in. The head has considerable porting and a 3 angle valve grind 8.5:1 comp. Should drive nice.
