4 members (54farmtruck, Danielbolt, Wooley, 1 invisible), 110 guests, and 0 robots.
Topics128,157
Posts1,056,875
Members48,456
I have a 1950 GMC 1-Ton pikup and I have the shock absorber brackets on the rear drive shaft which are mounted within the frame, and dont line up with anything. I do not have the upper support, and cant figure out where the upper support was located for it seems that it could only mount to the bed box horizontal rails, for its the only object above the lower supports, which is perculiar. I looked at the manual and it said "if used" perhaps there wasnt any on this model, but why are the lower supports there, hmmm? I need to figure this out for inspection requirements.
gas dude #393787 03/27/2008 2:46 AM
I had to weld all the unused openings on the firewall on my 1950 gmc 1-ton, to meet inspection requirements, why was there so many? One fitted all?
There should be a cross-member that it attaches to.
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
I guess I'll have to fabricate one, do you know where I can get a orginal? and Thank-you!
Post a topic in the "parts wanted" section, and no problem.
The holes were direct access points for the choke cable, throttle cable, voltage reg., temp. sender, oil sender, heater hoses, etc.
David Colter
you might get more input if you move this to the truck section.. just a thought
Redryder pix
My Hotrod
He's got 'er done!
David Colter
Were they double-action lever shocks? Then the mounts would be on the frame about 8" ahead of the axle, like on my 49 3/4t.
Yes, they are about that, What does your truck suspension look like?
A true '50 would have tube shocks, what is your serial number? It could be that you have a '49 registered as a '50. The shocks are about the only difference between the two years.
Paint & Body Shop moderator
If they are the modern style tube shocks on the rear axle they mount on the inside of the frame rails. There is a bracket assembly that is riveted to the frame with what looks like a long shouldered bolt with threads at the end. The loop end of the shock with its rubber bushings mounts on this. My '54 1 ton panel has this set up. If the shocks are the level arm style ,the shock body bolts thru the frame with either 1/2" or 5/8" bolts. My '48 1 ton pick up had this set up until I made the rear shocks mounts to use the modern style tube shocks. I used '85 full size Ford Bronco shocks for this application. Readily available at any local auto parts store.
