6 members (JW51, 55shaker, moparguy, Cosmo, Gdads51, 1 invisible), 108 guests, and 2 robots.
Topics128,069
Posts1,055,896
Members48,428
#393338 03/26/2008 3:10 AM
Searched with no results. Can anyone tell me the approximate weight of a 1941 GMC cc-303 which is a 2-ton I believe. It has a partial flat bed, 228 engine. Rough guess is fine. Thanks, Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
homer52 #393341 03/26/2008 3:12 AM
Rough guess: 6,000 lb, perhaps slightly less.
Grigg
Grigg #393385 03/26/2008 4:25 AM
CC-303, is a 300 series, which would be a 1 1/2 ton. A '47-'55 model 303-24 300 series 1 1/2 ton cab, & chassis, has an approximate weight of 4545lb.s Same truck with platform body is, 5275lb.s. So i'm going to guess the earlier trucks, would be a tad lighter.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
spanky #393485 03/26/2008 2:50 PM
Have you guys seen this picture? Do you know what the extra lever is for? I've only seen pictures of the truck so far. Thahttp://good-times.webshots.com/photo/2539518610101947398oXhRoqnks for the weight guestamate. Dave
1941 Chevy
homer52 #393486 03/26/2008 2:50 PM
1941 Chevy
homer52 #393645 03/26/2008 9:54 PM
I think that lever is for the mechanically shifted two speed rear axle.
But I could be wrong,
Grigg
Grigg #393696 03/27/2008 12:10 AM
That's my guess but I won't know for sure until I can see it in person. Thanks, Dave
1941 Chevy
homer52 #393974 03/27/2008 5:10 PM
Looks like it could also be to operate a pump or added equipment.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
homer52 #394632 03/29/2008 1:45 AM
Dave, It appears to be the same lever I have on my 46. It shifts an "extra" transmission/gearbox that you apparently also have. A fellow 'bolter told me they were called a "brownie" ??? Got me. He didn't know the reason for them (nor do I), but I can tell you this much, when you shift it into what I'll call low range, any box turtle can outrun you! With your power going through an additional gearbox, you will have some extra whining and groaning. It is much more noisy than my 54. But I find it an addtional piece of interesting truck history. Hope that helps. Scott
1954 Chevrolet 4400 1.5-Ton Dump Truck
1946 Chevy 1.5-Ton Dump Truck
1944 Chevrolet 1.5 Ton Dump Truck
1955 4400 Dump Truck
1951 2 Ton Stake Body
